Thanks in advance!
Hi Philip,
Do you know who you were working with on securing the quote? You can either comment here or email me at danielle.higgins@solarwinds.com
I agree. Almost 90% of our missions were created/customized by myself and the community team. The other 10% were out-of-the-box missions and as you can see, some of the language doesn't make perfect sense. I will make sure to change the verbiage on that specific mission as per your request. But freid is correct, following = "friend"ing.
Hope this helps,
Danielle
In order to be quoted I am sure you will have to supply something extremely substantial to an issue or product that they have. You will get thwack points for all kinds of other activities. Just play around and have fun, participate in anything that you can on the forums.
To follow someone, I am pretty sure you just add them as a friend. Give it a shot. I believe that is how I got my points for this!
Click on my name > Opens up my profile > top right corner click "add as a friend"
Hope this helps!
Regarding the quote, I provided all needed information for 2 different projects with 2 different end clients... but never received the points for those project. (1 has been purchased, the other one still pending).
I added you as a friend. If this is the way to "follow" people, the thwack mission should state it. Am I the only one that thinks like that?
Thank you!
If that happened I would contact on one of the Community professionals here on the site.
I accepted the friend request. See if you got that badge/mission/points. I agree that the wording is a little weird.
No worries for the specific terms. I wasn't sure I was catching the whole thing
Regarding the quotes, one project was with Justin Allen, the other with Nathan O'Brien.
Thanks !
I am a bit confused on the Taging a discussion mission. What does it mean by taging?
When you create a discussion, you'll see a field at the bottom before publish that allows you to enter key words or "tags" that help make your post more search-friendly.
