How can I mark all nodes to discover layer 3 and layer 2 topology without going to each node and listing the resources?
You can use Background Inventory, which Orion ordinarily uses during upgrade from previous versions to automatically assign new pollers for CPU, Memory and Topology. Background Inventory needs to be configured manually in Orion Database. You can use SQL statement below to enable re-inventorying of L2 and L3 pollers for all SNMP Nodes in DB:
BEGIN TRANSACTION
UPDATE dbo.[NodeSettings] SET SettingValue = SettingValue + ':L2'
WHERE SettingName = 'Core.NeedsInventory' AND SettingValue NOT LIKE '%L2%'
AND NodeID IN (SELECT NodeID FROM Nodes WHERE ObjectSubType LIKE 'SNMP')
INSERT INTO dbo.[NodeSettings]
SELECT NodeID AS NodeID, 'Core.NeedsInventory' AS SettingName, 'L2' AS SettingValue
FROM dbo.[Nodes] n WHERE n.ObjectSubType LIKE 'SNMP'
AND NodeID NOT IN (SELECT NodeID FROM dbo.[NodeSettings] WHERE SettingName = 'Core.NeedsInventory')
UPDATE dbo.[NodeSettings] SET SettingValue = SettingValue + ':L3'
WHERE SettingName = 'Core.NeedsInventory' AND SettingValue NOT LIKE '%L3%'
SELECT NodeID AS NodeID, 'Core.NeedsInventory' AS SettingName, 'L3' AS SettingValue
COMMIT TRANSACTION
Thank you so much. This worked great!
OK, that marked all the nodes, however topology is not working correctly.
Example:
I have a group of switches in a building that I want to build a map of. When I create a map, and include these switch and use "Connect Now" Some of the links do not get connected correctly on the main switch in the building.
NPM Topology on the node details view for the main switch is also incorrect.
I can look in the database table NodeCiscoCdpEntries, and the proper entries for the master switch are there, but they do not reflect what is show on connect now or the NPM topology.
Are you managing both end-point interfaces of those CDP connections in Orion? Have you noticed any connections with unknown source or destination interfaces on NPM Topology resource for the main switch ("?" instead of interface names)?
Managing both ends. And yes the main switch does have unknown conections.
@ zizi Any thing else?
Are you able to open a support ticket and upload diagnostics + a screenshot of the map with incorrect & missing connections highlighted? Please post back with the case number. Thanks.
