Hi all
I need to make on report on VM tags and vreplication value.
in which tables may I find the TAGS and the datas about replications ?
thanks a lot
Gildas
Unfortunately there is no monitoring of VMware tags or replications on Orion side at the moment.
I might be the only one to use VM replications
very disapointing
Are the VMAN 'Custom Label' values stored in the Orion database anywhere? If not, are they stored in the VMAN database accessible through SWQL?
lukas.vondruska Did you see my question? I didn't want to start a new thread since it was pretty similar to this topic and the thread was pretty new.
Unfortunately neither Orion database nor VMan swis service provider can be used to get VMan custom labels.
Extremely disappointing. Using VMware vCenter as the system of record would be fantastic. VMware Tags drive our Veeam Backups and all kinds of other reports that we run. Having Orion and the Virtualization Manager tie into the VMware APIs for tags would be great, because then we could simply add the tags in vCenter at the cluster, host, datastore, VM (etc.) level and it would automate EVERYTHING inside of Orion in terms of application groups and what we want to monitor. I cannot believe that SolarWinds has not capitalized on this yet and had I had my say, and known about this before we dropped a boatload of money into SolarWinds, I would have pushed really hard to keep looking elsewhere. This is BIG, BIG hole that SolarWinds need to fix in their monitoring software.
Boatload is an understatement...
Feel free to submit feature request at Submit a Ticket | SolarWinds Customer Portal
The vmware tags and annotations are available in VMAN but not Orion. I don't not see anything in VMAN specific to replication status though.
