Can Orion do any availability management of the servers i.e. uptime?
Glenn
Glenn,
Surely- We have out-of-the box availability reports. If you don't see what you are looking for there, it is simple to create a custom report.
Sorry I am very new to this environment, where would I find this information?
Out of the box NPM has a report for "Availability - Yeseterday" and "Availability - Last Month" and some more if you just login to NPM web interface and look at the Reports page. Process for getting there can vary depending on how your menus are set up, or if you have access to the windows box Start > All Programs > SolarWinds Orion > Alerting, Reporting, and Mapping > Report Writer and you can run the report queries from there
Ok thank you, I'll have a look at it.
Also whats the difference between alerts and reports?
Also read up on groups since most availability I have seen reported deals with groups of servers by location or functional workgroup. By adding your nodes to groups you can view and report on group availability.
