Dear Support,
we are facing issues using RES API "http request was forbidden with client authentication scheme 'Basic'" could an one help here.
Regards
Chethan Kumar G
Let's start by gathering some info about your setup.
Same issue here.
Example with PowerShell
$URI = 'https://primaryserver:17778/SolarWinds/InformationService/v3/Json/Query?query='
$Query = 'SELECT Top 10 Caption FROM Orion.Nodes'
Invoke-RestMethod -Uri "$URI$Query" -Method Get -Credential $Cred -Verbose
VERBOSE: GET https://primaryserver:17778/SolarWinds/InformationService/v3/Json/Query?query=SELECT Top 10 Caption FROM Orion.Nodes with 0-byte payload
Invoke-RestMethod : The remote server returned an error: (403) Forbidden.
Example with SWQL Studio using Orion (v3) over HTTPS
Is this issue specific to using AD accounts? In other words, do you have the same problem when using an Orion account?
Check the SWIS log for errors at the time of these requests (C:\ProgramData\SolarWinds\InformationService\v3.0\Orion.InformationService.log). Also check the "Application" windows event log on the Orion server.
Yes, Orion accounts works fine. Orion.InformationService.log doesn't have anything besides service start information, windows event log as well. I have a trace file I can share privately.
Ok. Send the trace to first.last@company.com and I'll take a look.
