I monitors interface statistics in real time select node and click discovery all interface but it show interface ???????
help me please.
Appears like a polling engine connectivity to your node issue. Could you share the log?
but I monitor node via NPM normally.
When you hit the Discover All CPUs button, did you see a discovery in progress message or is not doing anything at all?
not doing anything at all.
Does traceroute work and is it an issue only with this tool? Logs might help. Or please contact Support directly.
We now have the web interface displaying properly after doing the steps from the Success Center properly.
There is still an apparent bug with enumerating objects in Cisco 3750 and 3850 stacks if you select just one switch in the stack.
Thanks to all, especially moolmanee.m!
