Any ideas as to why this red dot is showing up on my map?
there is an interface on that system that is down down, and you have that object set to "show child status"
The only interfaces that are down are either admin down or "unplugged" so I would expect them to show up like that. For my case is the red dot intended to show up? Thanks for your response, for now I can just remove child status, but that is not my ideal fix.
yea, I thought the unplugged show up as down down...not sure what you are running though and I am ignant on anything non-cisco, so take it with a grain!
Are we talking about the same "unplugged"? I'm talking about the new "unplugged" interface feature in Orion.
nope, my bad. haven't been able to migrate as initial attempt web was WAY too slow. sorry.
