Hello
I have NPM primary, NPM 3 additional polling engines, SAM, SRM and STM in my environment. when can I upgrade additional polling engines is it immediately after the primary upgrade or after the upgrade of all the products.
Thanks.
You should first complete the upgrade on main Poller and then go your APEs... Alternatively you can refer the upgrade advisor if you are unsure of the compatibility...
So I need to upgrade my main poller followed by additional poller and then upgrade my other products with the help of advisor guide. Am I correct...??
Thank you Pratikmehta
I didnt understand the "upgrade my other products" part.. you have your plugins on the same server or different?
Other products means SAM , SRM and STM.
yes i got that.. but if its installed on the main poller itself then all u need to do is, upgrade the main poller and then your APEs...u dont need to separately upgrade each module unless its specified to be done after the core is upgraded... Upgrade advisor will give you a clear picture....
