Is it possible with application monitor to monitor space used in specific directories. Using app monitor version 4.2.0
Yes. SAM/APM includes a Directory Size monitor that provides precisely the functionality you describe.
I do not see this particular monitor type in my list of available
monitors. Should this one be available in 4.2.0 ?
Thanks Jeff
Jeffrey Cirisan
Technical Services | Data Communications Analyst
1 Mutual Avenue | Frankenmuth, MI | 48787-0001 | www.fmins.com
P 989.652.6121 x 2921 | F 989.652.3588 | C 989.295.4482
jeffrey.cirisan@fmins.com
Confidentiality Notice: This e-mail, including attachments, is intended solely
for the person or entity to which it is addressed and may contain confidential,
privileged and/or proprietary information. Any review, dissemination,
distribution, copying, printing, or other use of this e-mail by persons or
entities other than the addressee or his/her authorized agent is prohibited. If
you have received this e-mail in error, please contact the sender immediately
and delete the material from your computer.
In APM, navigate to Settings > APM Settings > Component Monitor Library and find the Directory Size Monitor near the top of the list.
Cool thanks. Another question - is there monitor template that could see
all of the counters in perfmon on a windows server
Thanks jeff
When I expand this it says that no" application monitor templates
containing directory size monitor". How would I add this monitor to a
node?
Jeff
Create a template, add that monitor, assign to node. Voila!
Settings > APM Settings > Create a new template. This link should get you started!
