uys help me.
Guys I can help connect VMan in orion console. All version is last.
The port are enable bettween server, telnet ok. The server are in some network.
Thanks for all your help not the Problem was in a certificate.
rschroeder
wluther
Help me ?
cjfranca Not sure what is going on with the screenshots, but they are not showing for me. Also, when I click them, they take me to a "440 Login Timeout" page, with a URL pointing to outlook.office.com.
Please attach those screenshots again, so we can see what is going on.
wluther thank you for your help.
cjfranca
Okay, so your VMAN server is using the default port, 443?
And you can ping your VMAN server from your Orion server?
And you can ping your Orion server from your VMAN server?
And you have allowed ports 17777 and 17778 through your firewall?
No have firewall between servers. The dafeault Port is 443 open. Yes can be
possíble ping servers.
Sem mais.Claudia França
2017-06-14 16:50 GMT-03:00 wluther <william.luther@gvtc.net>:
<http://thwack.solarwinds.com>You have been mentionedby wluther<https://thwack.solarwinds.com/people/wluther?et=notification.mention> *inRe: error to integrat VMAM in orion console. in THWACK* - View wluther'sreference to you<https://thwack.solarwinds.com/message/367370?et=notification.mention#367370>
by wluther
reference to you
