Hi guys
Can I monitor Cpu usage, Disk space and uptime on a Windows server with the basic Solarwinds Orion program or do I need the Application Monitor?
Is there any configuration required on the Windows servers themselfs?
Many thanks
Matt
Just Orion and on the servers they need SNMP running.
Orion can monitor your windows and *nix CPU, Physical Memory, Virtual Memory, and logical disk volumes in addition to network performance, all without the need for APM. All that is required on the server is to have SNMP installed and configured.
Awesome.
Cheers guys, have a good easter!
Orion can't fully monitor AIX. You can't monitor process CPU, process memory, or the number of processes running.
True, but this can be done using APM
This is easily done using the custom MIB poller built into Orion.
or the number of processes running This is easily done using the custom MIB poller built into Orion.
That would be a great field to have. Care to elaborate more on which OID(s) to look at? Considering Server 2k and 2k3? ;-)
Aaron
OID .1.3.6.1.2.1.25.1.6
aLTeReGo,
Please explain how you are monitoring AIX processes with the APM. I have had no luck with this, and SolarWinds Support is of no help. I have the legacy AM and the new APM ALX. Please provide exact details on how your AIX server are configured (AIX version, and/or NET-SNMP version) and how you have your AM and/or APM configured. The total number of processes running is also in reference to each process running, not an overall number. I am anxiously awaiting your reply! Thanks!
