Hi all,
I'm about to upgrade my WAAS and WAN Routers at site, I need to know our concurrect TCP and UDP connections. Can Netflow Analyser or NPM show me this information? I'd like to also see historical graphs etc?
thanks
Dave
NPM may be able to show you this information using custom pollers. See here for more details
[VIDEO] Create Custom Pollers in SolarWinds Network Performance Monitor (NPM)
Yes netflow will show you this. Just make sure netflow is configured on all your devices to point to solarwinds and you will be able to track traffic, ingress and egress by interface.
Can Netflow show historical graphs of how many connections per every 30mins?
Yes, it can, just set the time period under edit graphs
Hi James,
so I've just managed to get Admin access to Netflow. Which chart shows concurrent connections? I'm using NTA 4.0.1 and Orion Platform 2.0 with NPM 10.6.
I don't believe Netflow will show concurrent connections.
doing a "show ip cache flow" shows all concurrent connections on the router at that time, however I'd like to graph this into historical charts.
Yup that's correct. I think a firewall can collect this information but the external netflow programs don't seem to.
Doing a search in google doesn't show any options for netflow programs.
