Hi
My solarwinds application displays more objects down or Up. If someone has an idea
help me please. This is really urgent.
Best Regards,
Camel
Can you supply more information?
Is this NPM, SAM, or some other product?
It is the events for NPM
Kind Regards,
Okay, great.
Do ALL nodes show down, or do some show as up?
I rephrase my question: I do not have nodes down or up in the events type.
Excuse me repeat my question several times
Okay.
Navigate to your Orion server's desktop. Open Advanced Alerts Manager. Click on 'Configure Alerts'.
Choose the 'notify me if a node goes down' default alert.
In the 'trigger actions' tab, is 'NetPerfMon Event Log - Node ${NodeName} is ${Status}' one of the configured actions?
If not, add it.
If it is, go back the list of alerts and verify that your 'notify me if a node goes down' alert is enabled (checkbox on left).
Thanks.
And as a workaround to keep you going with your daily tasks, check the node downs from manage nodes view,
Settings -> Under Node & Group Management (Manage Nodes) -> Group by Filter on left hand side (Select [No Grouping] from drop down) -> Search for 'Down' against Show Nodes.
If you want to drill it down on a daily basis you can create a report or a email alert.
