I found this error on window 2003 server R2
How can i fix this?
Hi there,
Are you logged in as the local administrator on the system?
If not, then please do so and try again. If you can't log in to the system using a local administrator then hold off the installation until you can.
domain\domainadmin = wrong
localhost\administrator = correct
i login as local administrator in this ploblem
rsserver100 is computer name
The error definition is as follows: This problem occurs if the Windows Installer process has insufficient contiguous virtual memory to verify that the .msi package or the .msp package is correctly signed.
Microsoft has released a hotfix to address this issue here: http://www.microsoft.com/en-us/download/details.aspx?id=6724
Can you also confirm that there is enough disk space on C:\ / \ ?
Is the system starved of memory?
http://www.microsoft.com/en-us/download/details.aspx?id=6724 this link can fix this error but i found new error
Thank you for all of your help.
MS SQL Express 2008 installation issue during eval install
