hi
does solarwinds NCM product support microtk device like cisco ?
MikroTik devices are now supported out of the box.
Sometimes there may be issues caused by colorful lines the device sends in output. All these strange characters are information about line color. To turn off colorful output please change device login user name: {username}+c. For example: admin+c.
Regards,
Jiri
soplixx,
If the device has a CLI (Command Line Interface) then NCM should definitely be able to communicate and manage the device via Telnet or SSH. You may need to modify the Device Command Template that NCM is using to know what commands to pass the device based on the management commands you are trying to pass it. If that's the case, you may want to read through chapter 5 of the Orion NCM Admin Guide.
Thanks, Jason HensonLoop1 Systemshttp://www.Loop1Systems.com/
Anybody else interested in MicroTik devices, or has tried to develop templates for it and failed?
hi,
I've just tried to develop a template for a MikroTik device.I can now get snmp data from the device and log in via SSH but cannot get any output in the result window when attempting to run scripts.
The debug data from an export command shows --------------------[m[36m/interface[m [m[36methernet
[m[35mset[m 0 [m[32marp[m[33m=[menabled [m[32mauto-negotiation[m[33m=[m[32myes[m [m[32mcable-settings[m[33m=[mdefault [m[32mcomment[m[33m=[mUK [m[34;1m\
[m[32mdisable-running-check[m[33m=[m[32myes[m [m[32mdisabled[m[33m=[m[32myes[m [m[32mfull-duplex[m[33m=[m[32myes[m...---------------------
whilst the debug from a Cisco device shows
*** [192.168.x.x] Got 37 bytes
show run
Building configuration...
*** [192.168.x.x] Got 536 bytes
Current configuration : 7999 bytes
! Last configuration change at 15:23:07 GMT Mon Nov 28 2011 by monitor
! NVRAM config last updated at 17:59:25 GMT Wed Nov 23 2011 by monitor
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
no service password-encryption
service compress-config...-----------------
It seems that parsing is then unable to pickup relevant data to display.
I've opened a case with Solarwinds and provided debug files, templates and traces.
Vincent
Hello Vicent,
I'm also trying to get a NCM template for Mikrotik devices, so I can download and save the configs of mine.
Have you been successful building the Mikrotik template, and if so, would you mind sharing it here with us?
- Augusto
Hello Augusto,
We are currently trying to find some solution for Mikrotik. The problem is that Mikrotik CLI works in a completely different way that CLI's from other vendors, so we are not sure whether we can do something with just a device template (without changes in NCM code).
Although Jason's answer is correct for vast majority of devices, Mikrotik is an exception because of their non-standard CLI behaviour.
