Is there an easy way to view a table such as the following?
Are you looking for something like this? http://thwack.solarwinds.com/docs/DOC-167089
Yes, but that has the latest releases.
I'm looking for something more customized. I want to view only the patches we are deploying. That is, I want to view the current version we have published, and view the latest released version. The idea is to make it easy to see if I need to download/publish any new packages. I get the sync notification email, but it only says which packages were updated, and sometimes this doesn't necessarily mean a new version was released.
There's not currently a method to automate the aggregation of this specific data that I am aware of, but it wouldn't be too difficult to combine the results from a Patch Manager report with the table of third party patches spreadsheet. To pull the currently published third party updates I started off with this report, and made the modifications as shown below.
http://thwack.solarwinds.com/docs/DOC-167269
From here it's just a matter of exporting the report results to xls, and combine the 2 resources together.
This looks like what I'm looking for! Can you walk me through the steps on how to set that up?
Certainly. The steps would be the following:
1. Grab the report located on http://thwack.solarwinds.com/docs/DOC-167269
2. Import the above report into the Windows Server Updates Services Analytics reporting category.
3. Modify it to look exactly like the report in the screenshot below:
4. Run the report and export the results to xls.
5. Grab the latest Table of Third Party Patches from http://thwack.solarwinds.com/docs/DOC-167089
6. Open both documents and combine them in a way that meets your needs.
