Or any html at all.
I tried in the text box to use html and it didn't work.
Any pointers?
You need to create a transaction see here SolarWinds Web Performance Monitor Help
I have already done that and couldn't find anything in the documentation about alerting off of HTML headers.
Is there something I'm missing?
Hello in WPM I know, but, im SAM have this look. SolarWinds Online Help
I'll check it out. Thanks.
I believe the link below is what you were looking for. The link cjfranca provides was for the Custom HTML resource rather than SAM's HTTP Monitor.
http://www.solarwinds.com/documentation/en/flarehelp/SAM/default.htm#orionapmphcomponenttypeshttp.htm
Yes aLTeReGo thank you . arachenta this is link is correct. sorry fo rmy confusion.
