Is it possible to assign devices we are only pning for status (no smp) to a vendor so that it doesn't show up in the "unknown" vendor group?
If not please add this as a feature request. TY.
BB
Do you want to change all of your ICMP devices? If so what Vendor do you want to change them to?
These is not vendor dependent. I want to be able to assign any vendor to a device as needed. I just want to get rid of these icmp only devices in the unknown vendor group.
Not sure there is a way to do this now, unless you're willing to do a SQL Update on the DB.
Too complicated....SW...please put this in as a feature request. TY.
Hi Bryan--
I'll mark this for the PM.
M
I had a similar question; "How Can I Assign I Vendor or Machine Type to the HSRP IP Address that is just being Polled?"
Answer Provided by SolarWinds Trainer; Ed Barbieri
Within this SolarWinds Success Centre Information you will see that this can be done by editing the NodesData via the SolarWinds Database Manger.
