I need to create a new report that is almost identical to an existing report, but with a few different policies. Is there a way to copy the existing report to a new one, so that I dont have to re-create the whole report from scratch?
Not at present, but I've entered this as a feature request (and a good one!).
Certainly. Just edit an existing report and save it with a new name. Instructions can be found on pages 93-94 of the Administrator Guide:
2. If you want to edit an existing report, complete the following procedure:
a. Click Reports > View Report.
b. Click the report you want to view, and then click OK.
c. Click Modify Report.
3. Type a name for the report in the Report Title field.
[numerous options not shown, for brevity]
17. If you want to save the report, click Save Changes.
I should have been more specific about what I was looking for. I am looking to make a copy of a report in Orion Network Configuration Manager Policy Reporter, nor the NMC. My mistake. Is there a way to accomplish this?
thanks,
Jeremy
Any update on this capability?
Thanks!
If you are on current maintenance, the RC will be in your portal. The RC provides the ability to import and export policy reports, so you could achieve this by exporting, renaming, making changes, and importing it back in.
--Christine
