When I access File/Setting Menu ,Cirrus can't popup setting form.
Anybody like me ?
PLS tell me how to resolve this problem, thanks!
Thanks,i will try it
Hello Mithrilhall
I delete Cirrus and reinstall it, but no change...
Are you using the Cirrus node monitoring functionality, if you are try turning it off and see if that resolves the problem.
Jon
Thanks jonchill for your reply
After i turned "Node Monitoring" disable,the problem is not change...
And I install Cirrus on another server ,the "Setting" Menu seems also not work....
What OS version and regional language settings are specified on the server where you are installing Cirrus?
