Add any Double or Triple Custom Poller Radial Gauge into NodeDetail page.
I like this views.
Any comment?
Great job
Thanks alot!
Best Regards
Jack
Added custom Title for each Gaude
How do you get to the custom gauge program? I can't seem to get the gauges to come up in pairs. I pasted the files into the directory just as the txt file told me. Thanks for any help.
You must add a new resource. Admin/Manage Views/(select node detail page)/click "+"/Node Gauges - Real-time Gauges for Node Properties/Triple Custom Poller - Radial Gauge
This is also not working for me.
I would really like to use this and thanks for creating it just not able to make it work.
When going into the edit and adding the custom poller from the drop down and then submitting the page after adding this to a node I get"custom poller not assigned to crrent object"
I am probably doing something wrong so if you could lend a had that would be great.
This is still not working for me, not able to get the gauge to connect with the custom poller to get the gauge to even work.
Any help would be appreciated
This is working great. Good work!
Care to help out on how to make this work?
I am not able to get this working everytime I go into the nodes view and add the gauges and then go in and use the drop down to select the custom poller it tells me that the poller is not associated with this resource.
I can get the new resource to display, however, when editing the resource, I noticed only 2 of my pollers were available in the drop down. I have about 15 custom pollers running on all sorts of equipment. APCs, Cisco, Windows, etc. The only pollers I see present in the drop down are 1 Cisco Firewall poller (current connections), and a UPS active alarms.
Has anyone else encounted this. If so, how were you able to display all of your pollers in the drop down on the edit page. By the way, Gob, this is a great peice of work ou have given to the Orion community. Thanks!!!
I think it's broken for 9.5, due to a change in the way resources are handled.
Here's the new line from a .resource file (bold).
<!-- Title=Custom Poller - Radial Gauge --><!-- Level=7 --><!--#include Virtual=/NetPerfMon/scripts/Resource.asp --><!-- UpgradePath=/Orion/NetPerfMon/Resources/NodeGauges/CustomPollerRadialGauge.ascx -->
I'd guess we'll now need a .ascx file in that NodeGauges directory?
My triple gauges are gone after the upgrade to 9.5. Let me know if it actually still works, and I just need to reinstall or reconfigure my views by re-adding resources or something.
It is broken for me too ... Gob, can you please provide the new code for 9.5
I'll try. But this will be very slow. :(
Gob,
I understand that you are busy and have little time to work on something that should be built into the NPM software
I urge SW developers to look into it and make it a standard part the package because many people can benefit from such a feature.
Avnish
Bump
This still operates the same way, so if you would like double or triple gauges you would have to use the custom HTML resource to create
This looks very useful. I downloaded the zip file but I am new to this, are there any instructions and does this work in 9.5
Any word on this or something like it in 10.0? I really need to add multiple radial dials for APM components, not custom pollers.
