Did the issue ever get resolved with large banners taking forever and a day to get pushed to the device through snippets etc..? I'm still encountering it and trying to push it to one device takes forever and cripples the application.
Hi Pyro13g - I would suggest opening a support case. It looks like we have had a few cases like this and none of the solutions have been the same. They should be able to get this sorted out for you.
--Christine
Hi pyro--
What version of NCM are you running?
I'm marking this for the PM in case it needs to be a feature request or if she can chime in on status.
M
Would you mind posting the exact command script you're trying to run in NCM, target device types, and whether you're using SSH or Telnet for script execution?
Orion Network Configuration Manager SolarWinds Orion Network Configuration Manager 6.0 1999-2010 All Rights Reserved Orion Network Configuration Manager v6.0 DL500 Copyright 1999-2010 SolarWinds, Inc. All rights reserved Version 8.3.125
Telnet or SSH doesn't matter.
banner login @**************************************************************************** L E G A L N O T I C E -- Y O U M U S T R E A D ***************************************************************************** ** You must have explicit permission to access or configure this ** device. All activities performed on this device are logged and ** violations of this policy may result in criminal prosecution. ** ***************************************************************************** ** This system is for the use of authorized users only. Individuals using **this computer system without authority, or in excess of their authority, ** are subject to having all of their activities on this system monitored ** and recorded by system personnel. ** ** ** Anyone using this system expressly consents to such monitoring and is ** advised that if such monitoring reveals possible evidence of criminal ** activity, system personnel may provide the evidence of such monitoring ** to law enforcement officials. ** ***************************************************************************** UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE IS PROHIBITED *
Perhaps running a scheduled job might help, which would execute the scripts in parallel, especially if you have multiple devices.
That hangs the application and I have to force it closed. If you execute as a script you can watch it take up to the prompt timeout to move to the next line.
