I was asked this today by some of our application developers, does anyone know if APM can monitor applications using Java Management Extensions ?
We can't do this in 1.0, but we will be able to do it with a script in 2.0.
OK, so 2.0 is here (SP2 actually)... is this now possible? I want to use APM to monitor a tomcat server that has jmx installed. Can you please explain how to do this or point me to some documentation?
Shawn
While APM 2.0 can do this with a script, it's not something we've documented. From APM, the JMX counters can be polled with a script, but it's going to require a knowledge of JMX and scripting. I wish it were more out of the box, but not yet.
Hi Denny
do you have anything for providing help with monitoring tomcat ? like templates or scripts that others have used ?
Many thanks
Neil
Have you tried Nagios Exchange? APM 2.0 has a script ( in the built-in script directory..check your Start Menu) that will run a Nagios script and convert its output to an APM compatible format.
