I just enabled HTTPS for my Orion site. I have HTTPS required on IIS. I want to redirect anyone who browses to the HTTP site to HTTPS. What is the best way to handle this redirection?
HI Damienball
I am already using the same feature
First you need to understand that when you open a SSL (Https) site with Http it Gives you a specific error which is a html page call.
the idea is to replace the same page code with a script that changes the URL call.
Ensure you have made a copy of this page before proceeding.
I have replaced the 403.4 in IIS 6 with a .htm file that contains the following Javascript. It determines the http URL that the user went to and then redirects them to the https version. <Script language="JavaScript"> <!-- begin hide function goElseWhere() { var oldURL = window.location.hostname + window.location.pathname; var newURL = "https://" + oldURL; window.location = newURL; } goElseWhere(); // end hide --> </script>
That's what i was looking for! It's a little different in IIS7. You use the Error Pages menu instead of Custom Errors in the site properties. Thanks!
is there any look at making solarwinds website natively support SSL/HTTPS?
Also looking for a native solution, such that when Orion upgrades are performed you don't get error at end of config wizard complaining about unable to reach 'http:\\orion.domain:443" - it can figure out the port and url, but seems config wizard is hardcoded for http only.
in iis 7.x you can configure a redirect action on a website to return a 302 or 301 to the customer's browser that will redirect them.
Unfortunately this still breaks the config wizard, it doesn't follow redirect and so fails.
I switch our site to http so the config wizard can complete, and then back after an upgrade.
Im on board with this - we should have that option during installation - not have to "hack" the system after the fact.
Will this ever be native functionality?
