I´m installing NTA 3.6 module on NPM 9.5.1, but wizard send the next message:
Database configuration error:
Error while executing script- Must declare the scalar variable "@Script"
Some idea?
Do you know if you had an NTA eval or older version of NTA on this machine before?
It´s a new installation, NPM SLX 9.5.1 and NTA 3.6 with an independent SQL 2005 Enterprise Server. I found the installation wizard log:
2010-03-04 00:33:17,218 [1] INFO ConfigurationProgressScene - Shutting down services ...2010-03-04 00:33:17,234 [6] DEBUG ConfigurationProgressScene - Stopping service "NetPerfMonService".2010-03-04 00:34:30,500 [6] DEBUG ConfigurationProgressScene - Stopping service "SolarWindsAlertingEngine".2010-03-04 00:34:30,500 [6] DEBUG ConfigurationProgressScene - Stopping service "SolarWindsSyslogService".2010-03-04 00:34:30,500 [6] DEBUG ConfigurationProgressScene - Stopping service "SolarWindsTrapService".2010-03-04 00:34:30,500 [6] DEBUG ConfigurationProgressScene - Stopping service "SWJobSchedulerSvc".2010-03-04 00:34:30,500 [6] DEBUG ConfigurationProgressScene - Stopping service "SWJobEngineSvc".2010-03-04 00:34:30,515 [6] DEBUG ConfigurationProgressScene - Stopping service "OrionModuleEngine".2010-03-04 00:34:30,515 [6] DEBUG ConfigurationProgressScene - Stopping service "SWOrionInformationServicev1".2010-03-04 00:34:30,515 [6] DEBUG ConfigurationProgressScene - Stopping service "SWInfoServiceSvc".2010-03-04 00:34:30,546 [6] DEBUG ConfigurationProgressScene - Configuring Plugin "NetFlow Traffic Analyzer" - Component "NetFlow Database"2010-03-04 00:34:30,546 [1] INFO ConfigurationProgressScene - Updating Orion database. Processing NetFlowTrafficAnalysis.DBStructure file ...2010-03-04 00:34:31,265 [1] INFO ConfigurationProgressScene - Updating Orion database. Processing NetFlowDatabaseScheme.dbConfig file ...2010-03-04 00:34:34,296 [6] ERROR DBConfigProcessor - Error while executing script - Must declare the scalar variable "@Script"..2010-03-04 00:34:34,296 [6] ERROR DBConfigProcessor - Failing Sql command:CREATE PROCEDURE dbo.swsp_DropRoutineIfExists @routineName varchar(max)ASBEGINDECLARE @script nvarchar(max)SET @script=';'SELECT @script = @script +' DROP ' + ROUTINE_TYPE + ' ' + ROUTINE_SCHEMA + '.' + ROUTINE_NAME FROM INFORMATION_SCHEMA.ROUTINES WHERE ROUTINE_NAME=@routineNameEXEC sp_executesql @ScriptEND2010-03-04 00:34:34,296 [6] ERROR ConfigurationProgressScene - Error while executing script- Must declare the scalar variable "@Script".SolarWinds.ConfigurationWizard.Common.ConfigurationException: Error while executing script- Must declare the scalar variable "@Script". at SolarWinds.ConfigurationWizard.Plugin.Common.DBConfigProcessor.ExecuteSqlBatch(IDbConnection connection, String sqlQuery, ConfigurationLogDelegate configLog) at SolarWinds.ConfigurationWizard.Plugin.Common.DBConfigProcessor.Process(IDbConnection connection, ConfigurationProgressDelegate progress, String scriptFile, ConfigurationLogDelegate log) at SolarWinds.ConfigurationWizard.Plugin.Common.ModuleHelper.ConfigureDatabase(IOrionConfigHost host, ConfigurationProgressDelegate progress, ConfigurationLogDelegate log, String dbStructureFile, String dbConfigFile, String initialWebConfigFile) at SolarWinds.ConfigurationWizard.Plugin.NetFlow.NetFlowPlugin.ConfigureDatabase(IOrionConfigHost host, ConfigurationProgressDelegate progress, ConfigurationLogDelegate log) at SolarWinds.ConfigurationWizard.Plugin.NetFlow.NetFlowPlugin.DoConfigure(IOrionConfigHost host, IComponentInfo component, ConfigurationProgressDelegate progress, ConfigurationLogDelegate log) at SolarWinds.ConfigurationWizard.Plugin.Common.OrionConfigPlugin.SolarWinds.ConfigurationWizard.Common.IOrionConfigPlugin.DoConfig(IOrionConfigHost host, IComponentInfo component, ConfigurationProgressDelegate progress, ConfigurationLogDelegate log) at SolarWinds.ConfigurationWizard.Host.ConfigurationProgressScene.DoConfigForComponent(IOrionConfigHost host, Int32 componentId)2010-03-04 00:34:34,453 [1] DEBUG IIS6Configurator - Parsed IIS binding string of ":8090:". Address is "" and port is "8090"2010-03-04 00:34:34,468 [1] DEBUG IISHelper - Detecting if IIS6 is installed: True2010-03-04 00:34:34,546 [1] DEBUG SqlHelper - SQL: SELECT TOP 1 NodeID FROM Nodes2010-03-04 00:35:06,421 [1] DEBUG SqlHelper - SQL: SELECT TOP 1 NodeID FROM Nodes
what's your collation schema? I would say, that you have CASE SENSITIVE and that's probably the problem.
thanks
Correct, and we don't support CASE SENSITIVE DB configurations at this point.
You are Rigth!!!
I change the collation schema of SQL 2005 server database to Case Insensitive:
I need to:
;-) Thank´s
