All, I need to develop a NetFlow Report which shows what countries have been found as depicted in the Top xx Countries. Once I get the basics I can then do several reports based upon a time period.
Any help would be appreciated.
Try this one. It gives a macro error I have not been able to figure out but seems to work.
Andy, I appreciate the report. I think it will help get me where I need to get but I have a question. You might be able to illuminate me as you know the backend of NetFlow.....
When I put the SQL embeded in the report into SQL I get different results than when I run the report. I have tried this several times but each time I get different data for the countries.
Do you consistently get one specific result for using the GUI and an other specific result using the copied SQL?
Yes, and no....
Can we PM on this since some of this is 'sensitive' data. Once we get a solution we can go back live.
Should I open a ticket?
I'm looking into it now. Give me a couple hours or so. Don't open a ticket. Creating/troubleshooting custom reports is out of scope for them.
