My question is, what are the server specs to be able to run a stable Network Monitoring System base on the number of elements?
This is what I have right now on my servers:
Elements 7669
Network Node Elements 614
Interface Elements 5530
Volume Elements 1525
My specs are on my signature below and so far the RAM on the SQL Server is constantly on 95% (28.8Gig) which I read is normal due to SQL.exe memory hog.
We are going to buy another Polling Engine server Jan 2011. Just waiting for the elements to reach 8000 which I read was the maximum number of elements per server. With the polling engine server, is there a server spec recommendation? The server is purely going to act as a polling engine and nothing else. Some node will be migrated from the current Web Server to the new Polling Engine to reduce the stress it's currently experiencing.
We have also purchase APM AL100 which we may upgrade to AL500 depending on the features. Adding the APM module to our existing Web Server may make things worse until we get our 2nd polling engine server.
