I've added a few Resources to my SW installation but when I go to add the resource to a view, I don't see it. How can I get SW to view the newly created Resources?
Thanks in advance for your help.
I found out what was going on. There apparently is two installations of Solarwinds. C:drive and d:drive (the primary directory). I was updating the C:drive which obviously wouldn't propagate to the webserver. Problem resolved! Thanks for everyone help.
What have you done so far to try to find the resources to add to the view?
I've created the resource,
copied it to C:\Inetpub\SolarWinds\NetPerfMon\Resources\1-1-SummaryReports
Created a Custom View
But when I go to add the resource, it is not there. I'm wondering what am I doing wrong. Am I missing a step?
Did you use the search tool above the node list? If the resource is in a group, did you make sure you were looking in the appropriate group? (If you haven't already, check page 62 of the Administrator Guide for instructions on viewing node resources.)
I guess I am a little confused. I recently added the unManagedNodes.Resource to my resource directory. Can I simply add that Resource to a Home Page view? If so, how do I do it? I know how to edit views that are already built, but I want to add a new resource to a Home Page view that I've newly created. Is this possible?
If you've created a new view, you'll need to set that view as your home page.
