Hi all,
I was wondering whether it is possible to create a report that will gather information on all the routers monitoring in Orion?
The information we would be interested in is -
Device Type
Model Number
OS Version and the such.
Is this possible?
There is an inventory report under Node Reports called IOS Versions of Cisco Devices. Is that what you are looking for?
Nope, this report gathers information for all cisco devices only.
I want the information for all the routers from all of our manufacturers, not just Cisco stuff.
Then just copy the report and take out the (Nodes.Vendor = 'Cisco') part. That should do the trick. We only have routers from Cisco, so I can't see if the fields are the same for any other vendor.
Wouldn't work though as it would return every single device.
I want only routers, from all vendors.
Use ((Nodes.Vendor = 'Cisco') or (Nodes.Vendor = 'Juniper') or (Nodes.Vendor = 'Huang')), or do you use that many vendors that you can't put them in a list? I don't know if there is a "device type" field in Solarwinds. Another solution would be to put the "router" designation in a comment field. Then you can use that as a criterion in the report.
