We've had a lot of feedback from EOC users, and the next release is going to focus on performance. There are a number of features we're also working on, and those will be coming up soon after the performance release.
--Christine
Christine,
One of our frustrations with EOC is the lack of ability to pull global reports. We currently have two separate NPM deployments and will be adding two more in Q4 2010 and Q1 2011. Is this something that will be addressed in the new release?
Derrick
Hi Slinky103 - we're working almost exclusively on performance right now, but the global reports are on the road map to be addressed in the next batch of features. We've had this request quite often, and it's very high priority.
are you guys planning on doing AD groups or an everyone soon? with a couple hundred users on our eoc, it is tedious to add them then go in and have to add credentials one by one for each of the 5 NPM servers. not to mention when a password is changed and we have to go back through them all to update them.
We sure are... that's something we have been working on. We're in the beta right now, if you would be interested in participating in the RC - let me know and I'll get you added to the list - christine.bentsen@solarwinds.com.
sounds great. this would make EOC a million times better and save me some time to do some work on the maps and such rather than spend extra time adding and changing users. Thanks
Is the RC still running for the next release? I would like to jump in on it if I can.
Absolutely. I will provision you asap. Right now we're doing a smallish first wave, but if anyone else on this thread would like to get in on the first wave please let me know.
Hi Derrick (and others who have an opinion on this) - We are looking at putting global reports into EOC. If this were to be implemented in your most ideal way - what would the reports look like? What data would you most like to see? How would you want to use the reports?
Hi everyone - the EOC 1.3 RC 2 is now available in the portal of all current customers. Like all RCs, this is a fully supported release.
Things to look for:
1. Dramatically improved performance throughout the application. This release focused on performance, and you will definitely see the results!
2. Support for AD groups.
3. Ability to set a home view for a user.
4. Bug fixes.
We're looking forward to your feedback.
Does this release also include consolidate reporting?
Derik
The release that is in RC right now, no.
Per Christine's previous comment:
We're working almost exclusively on performance right now, but the global reports are on the road map to be addressed in the next batch of features. We've had this request quite often, and it's very high priority.
Once we get the follow on release locked down feature wise we will post an updated what we are working on post.
Brandon,
Thanks for the reply, I was just making sure nothing had changed from Christine's previous postings. As for additional information on what types of reports; most of my Customers would like to take the same reporting available in A single Orion and be able to incorporate them together into a Single Report. I have also gotten lots of feedback about having to manually copy reports to additional web servers and would like to have some automated options to where they could push reports in those size environments.
I am not sure if there is a different forum for new features, but here one that would help a lot:
when assigning roles to users, the role should also include the list of Orions that the user has permission to view. I find that I add the user and forget to go back into the user to enable the Orions.
I will add more later, but I just wanted to make sure this was the place to post new features or not.
Scott
Is it possible to not gray out the entire screen when refreshing? For the operators, they want to make sure they can look up at any time and view what is going on. The 20 sec gray out time for the entire console is not being received well.
Haven't heard much about EOC for months. When is the next release? Is search for interface coming in the new release?
BB
Well we just released v1.3 not too long ago and are currently working on EOC 1.3 SP1, which is currently in customer acceptance. I have a list of things I am looking to get done and working with Dev on sizing, scoping etc. With that being said, we are getting ready to kick off on the next release soon. Once I get the details locked down a little tighter I will update this post with what we are aiming to get done.
One item high on my list is to bring module support up to date. We added the Virtualization tab, released new product UDT and have another one coming out later on, IPAM does not plug into EOC etc.
What are your top 3?
EOC really lack of ability. My customer complain that even to show a simple total nodes in network, total nodes up and total nodes down could not be done. I hope there would be SQL based reporting resource in the next release..
Cheers,
Rudi
Rudi, I understand that SQL based reporting resource would be versatile, anyway if you need to display number of up/down nodes, you can do it in the Global Node Status by Site resource when you group nodes by Status column.
Is there any chance of getting more graphics integrated into this. For example in NTA there are some nice pie charts that would look really neat filling up the 60" screens at my work. More Graphical presentations would be nice!
What is being done with EOC today? We haven't seen any new versions, patches, etc in months. With NPM going to 10.2.2 I'm seeing event icons with X now since EOC doesn't seem to have a icon for it. Where are the feature requests?
I have one. It's tiresome to have to pull the same report data from X amount of pollers. We need EOC to pull the same data from all pollers for the same report. I'm sure there are more.
I have several customers that can really benefit from EOC, but their use of SolarWinds has grown way beyond the original set of EOC supported modules (NPM, APM, NTA, IPSLA, NCM). We have customers that need to have rollups from regions that include:
We need some updates about the future of EOC. The feature requests for generating reports, etc. across the regions, as well as updates, support for current revisions, etc. are all very important to us.
Please let us know where things are at.
