but ${NodeName} doesnt is not even running Exchange IIS.
What could be wrong?
Is it possible that someone added this server to the poller and alert, not knowing that this service doesn't need to be monitored on this particular device? Can you simply remove it from the poller/alert?
please elaborate. Where do I find the poller?
What I've done:
" Trigger this Alert for any Application that matches the following condition"
Trigger Alert when all of the following apply
Application Name is equal to Internet Information Server
Application Status is equal to Down
Any ideas?
We are not running the Application Monitor, so perhaps someone else in Thwackville can help. The only suggestion I can offer in the meantime is to exclude the nodes in question from the alert.
can someone explain how are my alert tells me that IIS is down and then four minutes later its up. Only thing this server is not running IIS.
What can it be?
Add this clause tho remove some Nodes from the alert- and see if this helps.
Alert when app name = ‘Some Name’ AND status = ‘Not UP’ AND NodeName not = ‘Some Node Name’
