I would like to creat a view that will display specific node details, CPU, bps in/out etc. It seems that when I go to customize a view and add resources, I can add the top XX, but not specific nodes. How would one go about this.
First create Custom Property in the Custom Prooerty Editor.
Second when you go to add the Top XX choose exactly that, Top XX, then once it is on the web page you can edit that specific resource, and add a filter to it. The filter is where your new Custom Property equals what you are looking for.
Here are a couple screen shots for you.
On the edit page tyoe in the name of your Custom Property and = to your value.
That should do it. Good luck
Thanks. How does one find out the id/name of the specific interface so I can place it in the Filter Interface field
Click on the web interface in the web console, look at the URL. Like:
orion/.../InterfaceDetails.aspx
That is interface ID 6263
Thanks.
I did what you suggested. If I enter NetObject=I:1295 in the filter interfaces I receive an error message saying that the SQL query is incorrectly formatted
try InterfaceID = 1295
