Hello,
We recently change the URL to access the WEB interface. I noticed now that when I click on the Reports tab. The page can not be found. It still has the old link, where do I edit that?
thanks.
Are you saying that the reports tab on the new web server are pointed to the old server? If so, run config wizard again on the web server and follow the admin guide seection 27 from step 9 on down.
It's the same server. Basically the URL changed. Just as an example prvieous http://server123 new= http://serverABC.
So when I click on the reports tab it still shows http://server123/Reports. It needs to point to http://serverABC/Reports
OK. Can you tell me exactly what you have done to this point? How did you change the URL?
I haven't done anything at this point. But our engineering group change the DNS. Last friday. Everything works fine when logging in with the new URL, it's when I click on the reports tab shows and makes reference to the old link.
Can you use the IP address and let DSN resolve it?
If not, I think you'll have to talk with the engineering group there.
