I'm creating a record where the website has a security certificate pop-up when logging in. I already tried to use the XY condition, but still to no avail.
Appreciate your response. Thank you.
Regards,
Manilyn
Hello Manilyn,
if you mean "client certificate" that user uses to authenticate on the website, then WPM has built-in support for that. It is able to save certificate with recording and use it during playback. There should be nothing special needed for that, it's transparent for user.
Can you post some screenshot of how exactly it looks like in WPM?
Hi Jiri,
Thank you for your response.
I meant the web user certificate. We only used our account to access the workstation which is different certificate. So when I tried to use the WPM recorder, I've seen two certificates (communication certificates where it prompted the user certificate that I logged in and the confirm certificate from the web). I wasn't able to get through when i clicked the OK Button. I was successfully accessed the web in IE browser by the way.
PSA for your reference.
I see the issue now. In order to include cetificate in WPM recording, WPM has to be able to export that certificate with private key. The error says that your current certificate does not have private key marked as exportable. In that case there are two options.
So unless you have many players, it may be easier to go, log into each player and install client certificate on each of them.
Thank you for your advice. I already exported and imported the web user license. However, the license doesn't exist only on the WPM recorder because I already tried this using IE browser and I was successfully accessed the web.
Can you open the certificate and check if it has "Enhanced Key Usage" containing "Client authentication (1.3.6.1.5.5.7.3.2)"? If you open certificates console, go to properties for particular certificate and select "Details" tab, there is a filed "Enhanced Key Usage". If it does not contain "Client Authentication" then WPM does not see the certificate and does not know how to use it.
