I'm working on reports to pull back arp and cdp neighbor info from HP core device. Has anyone done this or have any guidance to make these work?
Hi keeusa,
The HP.Switch.2500 device type in CatTools already has support for an ARP report. (Report.ARP table).
Have you tried using this device type with your HP?
With regards to the CDP Neighbors report, this currently is unsupported. I'd therefore recommend opening a support ticket and see about getting this added as a feature request.
Regards,
Steve
My Report is working but it is only pulling certain ports, looks like I get all of my servers and a couple laptops but I agerage interogating 4 ports per switch consistenly the same ports, are there any limitations for the 2500 Device Type?
Dana
Hi Dana,
Can you verify please which report you are referring to here?
The ARP Report
Dana,
The CatTools ARP table report simply issues a 'show arp' command and then parses the results.
Can you check the 'show arp' output with a manual telnet/ssh session to the device, and compare it to the data shown in the CatTools ARP report.
If you find there is a difference in the data, then please raise a support ticket as this will need to be looked into and we will need to get some device captures from you.
