New to NPM, but not to server monitoring. Discovered nodes OK with disk and memory watchers. Moved memory to critical, but the node still shows as green. Does the memory in critical propagate up to the parent objects?
Hi John--
Unfortunately, no, memory in critical does not propagte upwards. I will make sure the Product Manager sees this...maybe it can be logged as a feature request.
M
Is it just memory that does not propagate or is it that all the collectors at the node level such as drive space also does not propagate to the parent node. So basically the node view is just for a ping reply status?
Make sure SQL is performing correctly memory-wise. This is critical to a smooth running Orion NPM installation.
No, interface details do propagate to the node. It's just the memory info that doesn't.
I have also made disk volume usage go to a warning state, but it also does not propagate to the node. Based on what I see, it is only the interface which propagates to the node.
Am I doing something wrong or is it just the limitation of the product? It was my understanding that the node would reflect the status of the child objects.
You are correct--it is just the interface that propagates to the node. I guess it is a product limitation. I will make sure the product managers see this post and add it as a feature request.
