How does it works... ive enabled the tool on one of the servers ... where does it store the log file i mean in which directory ???????
You can create a rule that says if you see this event type from this agent send an email or append to text file, yes.
Any time an active response is initiated, events will be generated and stored on the appliance. If you search for InternalCommands alerts in nDepth (or with a filter) or use the "SolarWinds Actions Report" you should be able to find anything an active response connector has done.
HI Nicole
Thanks for replying
I'm still bemused with this .. .. is it like .. ( if i installed this tool ) ....
is it possible to create aa rule or filter an agent .. like (if this alert occurs from this agent ... do this actions append to a particular TXT file or CSV file ??? can i do like this ... ?????????
i'm having problem with this( append txt file ) rule when trying to create a rule for a particular alert i'm trying to write detection time to the txt but its not allowing me to do that its saying incompatible parameter
any help ???
can somebody shed some light on it pleaseeeeeee ???? this is very essential thing for me to implement on my project
That message is a warning - it is possible the rule and action will fire even though it's there. (It's also possible the rule will fire but the action will fail, but I haven't reproduced this myself to be sure one way or the other.)
What I'd do:
If you never see data in the text file even after doing those things, chances are something else is wrong. You may need to open a support case to get this diagnosed faster.
Thanks nicole for replying
1. i cant use email because there is no mail sever in my network
2 i've doubled checked it it the appropriate parameter
3 i've use rest of the categories like eventinfo , etc... they are working but when i tried detection time .. it says incompatible parameter??
ive raised a case for this today .. they said they gonna send this issue to the development team, but they have gave me a timeline for it ?? can you push this forward
Thanks in advance
Have you ignored the warning, saved anyway, and verified it does not work, or are you just reporting the warning? The warning is just a warning, but I cannot say for sure what effect that has. Before I check, I want to be clear what you're experiencing.
crishna - Unfortunately, we cannot give specific timelines for such requests. Did you create an Idea for this on the LEM Feature Request forum? The community can then vote on your feature request and show that this feature is widely needed.
We have confirmed this active response works fine - if you ignore the warning (and everything else is properly configured) DetectionTime will be written to the specified file. Make sure that you have the "Append Text to File" active response configured on the system you want to use it on, double check the rule and the response (ignore the mismatch warning), and all should be well. Support should also be following up.
