Have any one a solution for config backup for Cisco Concentrator 3005 in Cirrus ?
I can get it to work in Kiwi CatTools ;-)
I would love to know the answer to this as well. I can get it to work with Kiwi also.
Does anyone have an update to this thread? I am having the same issue. I am using telnet and have verified that my login is correct, but I am not able to pull down the config off the concentrator. I would appreciate any info on this.
Is this a menu driven VPN? I have the Cisco VPN3030 and it's menu driven to get the file. I have a ticket open with support to write a template for this. I opened it back in mid-December and haven't gotten anything back yet.BB
Yes, it is command-line menu driven. I believe the entire VPN3000 suite is all that way. Cool. If you hear back from support, do you think you could let me know and/or forward the template my way? I would appreciate it. Thanks for the reply.
Let me put my request in the hat as well. Given the complexity and importance of the VPN3000 series devices, I'm surprised it hasn't been addressed already. I'd also like to see VG248's get added as well, though these may be a bit tougher. At the same time, if you go through their menu, there is an option to view the text config.
