Hello,
we are using the Kiwi CAT Tools 3.6 to backup Juniper Routers but we have also Bintec/Funkwerk/Teldat routers in use.
Maybe anybody of you have already add this kind of Router and can give me the Script-File please?
Regards,
SSP Europe
You may well be correct in that the file is still in the process of being transferred after the activity is reporting the failure.
However CatTools reporting a failure may be due to one of a number of issues:
Any chance you can provide a sample of a manual session to the device showing the commands and responses from when the TFTP command is sent?
Steve
SSP Europe,
You may like to try using the Generic.Device (device type) in CatTools which also has the Variations feature implemented.
The Variations feature allows you to customize (override) some of the default script variables to better suit your device.
Hello Steve,
thanks for your answer.
I already knew that I can change the variation features. But I also have to add the command that Kiwi knows how to backup the Bintec device, and I thought I must add a Script to do that?
The Generic.Device type is based around Cisco IOS type of responses, however with the variations feature, you still have the option to override the default script variables (such as the command used to backup the device, etc.) within the variations options.
If you device is very non-standard though, then you may need to create a custom script yes... but it really depends on how the device responds.
Give the Generic.Device and variations feature a go and post back how you get on.
Hello again Steve,
sorry for the long response time, I was on holidays.
The Problem is, that my device is a little bit special . In the Variation settings I can change the commands to show running config for example, but in my case I just have the option to backup my device via TFTP. And I didn´t see a option to Backup the Device via TFTP in the Variation settings.
Regards SSP
The Generic.Device supports the Device.Backup.TFTP activity.
There are a number of options within that activity which will hopefully enable you to backup the device via TFTP.
Give this a try and post back with your results.
