Can some one suggest me on this.
Still waiting for response .I was able to create this for 1 week /last hour / month but not for a particular business hours.
you have to use timestamp limitations in your datasource:
-ZackM
Could you please share the screen short of the next step.I mean what would be the custom table for this.
I want to create
Min/Max Receive & Transmit Bandwidth during local business hours - Last 7 days
So please share me the screenshot how to do this
I have tried on this way but no data is fetching from server .
looks like you've found a bug in the web report engine. I'm seeing the same issues on this side. I would suggest opening a ticket with support to get a resolution.
in the meantime, you could get a similar report via a custom SQL query as such:
SELECT n.Caption 'Device' ,i.Caption 'Interface' ,MAX(In_Maxbps) 'Peak Receive bps' ,MIN(In_Minbps) 'Min Receive bps' ,MAX(Out_Maxbps) 'Peak Transmit bps' ,MIN(Out_Minbps) 'Min Transmit bps'FROM InterfaceTraffic tJOIN Interfaces i ON i.InterfaceID = t.InterfaceIDJOIN Nodes n ON n.NodeID = t.NodeIDWHERE t.DateTime > (GETDATE()-7)AND ( (DATEPART(WEEKDAY, t.DateTime) <> 1) AND -- Not Sunday (DATEPART(WEEKDAY, t.DateTime) <> 7) AND -- Not Saturday (CAST(t.DateTime AS TIME) BETWEEN '06:30' AND '18:30') --Between 6:30am and 6:30pm)GROUP BY n.Caption, i.CaptionORDER BY n.Caption, i.Caption
I'm getting below error while executing
Msg 8153, Level 0, State 1, Line 1
Warning: Null value is eliminated by an aggregate or other SET operation.
Could you please suggest on this
that's just a warning that your original data set had NULL values in it that were removed during the aggregate functions.
basically, in the joining of InterfaceTraffic to Interfaces to Nodes, there were columns with NULL values; but after the SELECT clause finished, the NULL values were eliminated from the final results (because NULL was not the MIN or MAX for anything).
It's a warning, not an error, should be able to be ignored.
