i had migrate Orion V7 to V8 and it goes ok but when i migrate it to v9 i had the following error: "that software license key is for a different computer/software package combination"
Any Help Please
Hi Mohamed,
You should open a ticket with the customer service to ensure you can correctly license your Orion NPM.
To Open a Ticket: http://www.solarwinds.com/support/ticket
In the form, select Customer Service.
-Yann
Dear Yann;
one more question, i had migrate from orion 7 to orion 8 with the same license and there was no problem in that
the question is after migration from orion v 8.5 to orion 9 shall i deactivate the license for the orion 7 from the license manager?
HTH,
Yann
Thanks for you quick response
So you want to say that i have to uninstall orion version 8 first and then install orion 9?
and if that so , the problem is that iam migrating on the same server?
No I meant that once you have Orion upgraded to Orion 9, you do not need to keep the old licenses on your server Orion v7 & v8. However if you keep them installed it will not affect your Orion v9 installation.
That's fine just install Orion v9 on the top of Orion v8 and point the configuration wizard to the same database, everything should upgrade smoothly.
