Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
NetPerfMon-NetObjects.SnapShot
surajjadhav
Hello,
Is there any code available using which I can display the NetPerfMon-NetObjects.SnapShot in IIS? Cause right now when I host the site with NetPerfMon-NetObjects.SnapShot default document ...It does not open the XML - instead asks to save.
I searched for xml webhosting and found that I need to call the XML file using codes e.g. Java,XDL,CSS in a html page and so on.
This is something I am not understanding....If any site which can guide me - It will be a great help.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Do a search in this forum for "XML".
There have been other posts on this subject.
-=Cheers=-
NG
masoncooper
Since the XML file if only data, you need some way of describing how you want the data displayed. The way I displayed our snapshot file was by loading an XML stylesheet (XSL) and applied the XML data to it.
The entire process requires 3 files and no server-side processing (it's all done at the client-side)
First, I have my XSL sheet, it is fairly basic but it allows us to see what we need to see
--------Systems.xsl--------
<?xml version="1.0"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="
">www.w3.org/.../Transform">
<xsl:template match="/">
<html>
<body>
<h2>System Status for <xsl:value-of select="NetPerfmon/Snapshot/
@TimeStamp"
;/></h2>
<table border="1">
<tr bgcolor="#9acd32">
<th align="left">Device</th>
<th align="left">Interface</th>
<th align="left">Status</th>
<th align="left">% In</th>
<th align="left">% Out</th>
<th aligh="left">In</th>
<th aligh="left">Out</th>
<th aligh="left">Max In Today</th>
<th aligh="left">Max Out Today</th>
</tr>
<xsl:for-each select="NetPerfMon/NetworkNodes/NetworkNode/Interfaces/Interface">
<tr>
<td><xsl:value-of select="../../
@NodeName"
;/></td>
@InterfaceCaption"
;/></td>
@OperStatus"
;/></td>
<xsl:choose>
<xsl:when test="RawData/
@InPercentUtil
> 50">
<td bgcolor="red"><xsl:value-of select="
@InPercentUtil"
;/></td>
</xsl:when>
<xsl:otherwise>
@InPercentUtil"
;/></td>
</xsl:otherwise>
</xsl:choose>
<xsl:choose>
@OutPercentUtil
> 50">
@OutPercentUtil"
;/></td>
</xsl:when>
<xsl:otherwise>
@OutPercentUtil"
;/></td>
</xsl:otherwise>
</xsl:choose>
@InBps"
;/></td>
@OutBps"
;/></td>
@MaxInBpsToday"
;/></td>
@MaxOutBpsToday"
;/></td>
</tr>
</xsl:for-each>
</table>
</body>
</html>
</xsl:template></xsl:stylesheet>
Notice the xsl:for-each, this will go through all interfaces in NetPerfMon/NetworkNodes/NetworkNode/Interfaces
And of course you have your NetPerfMon-NetObjects.Snapshot file
And lastly you bring the two together with a basic HTML file
-------SystemStatus.htm-------
<html>
<head><META HTTP-EQUIV="refresh" content="300"></head>
<body><script type="text/javascript">// Load XML
var xml = new ActiveXObject("Microsoft.XMLDOM")
xml.async = false
xml.load("NetPerfMon-NetObjects.SnapShot")
// Load XSL
var xsl = new ActiveXObject("Microsoft.XMLDOM")
xsl.async = false
xsl.load("Systems.xsl")
// Transform
document.write(xml.transformNode(xsl))</script>
</body>
</html>
This is also pretty basic, just a little bit of javascript.
We load both files into XMLDOM objects and then use the transformNode method of the XML file to create our new layout.
I'd strongly recommend looking at
www.w3schools.com/.../xsl_languages.asp
for more info on stylesheets, they are pretty powerful and best of all, they don't necessarily require server-side processing.
Hope this helps!
Cooper & Scully
900 Jackson St Suite 100
Dallas, TX 75202
mason.cooper@cooperscully.com
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
