I have orion npm 8.1.0 installed. My website runs soo slow. Any ideas?
you can try
Thanks for the info, but that didnt work. It a hp g5 sserver fresh build. I am thinking it might have something to do with the setup
I would strongly recommmend upgrading to NPM 9.1 SP1. Web performance is much better in the current version than in 8.1.
Yeh. Thats a $3000 solution I cant afford right now.
Understood. If you're looking for more help, you'll get farther with more details about your environment e.g., -- hardware, database specs, load times by resource, etc.
