I was wondering if anyone knew of a way to have a view within SolarWinds Orion which would show a list of all the last full backups completed on an Exchange Mailbox Database?
Simply add a Custom Table Resource to any Summary View, select 'AppInsight for SQL: Database' as the data source and add the database 'Name' and 'Last Backup' fields to the table.
Thanks for this, I have done what you have suggested and I now get this view:
Ideally I am after a view of each mailbox database.
You are correct, the backup information shown in AppInsight for Exchange is not available in the Custom Table resource. I have logged this issue internally under SAM-3833.
Thanks for looking into this. Will you be able to post an update here when you hear back?
This thread is indeed referenced in the case.
Did anything ever come of this, I'm trying to create a table which shows my exchange DBs with last full and incremental backups but i notice the values are still not showing under AppInsight for Exchange: Databases
