Map Maker does not support placing UnDP's on a map. I'll get this added as a feature request.
Thanks Casey.
can you answer a question for me?
is there a reference someplace which mentions those variables which will work on maps?
for instance, today i'm trying to place things like ${VolumePercentUsed} but i get nothing...so i assume those for Volume might not work either.
Yes... thank you Casey... I too would like to add UDP variable to my map!... Thanks for bringing it to there attention Ichance
You can add any alert (i.e. SQL) variable to the information field in a label on a map. For instance, you could right click on the node label and use the ${Status} variable to indicate the status of the node on the map. The possibiolities are many. The alert variables are listed in an Appendix at the end of the Orion admin guide.
Hope this helps.
Thanks borgan...
It helps as far as basic values... still cant get values from the UDP...
