Can the latest RC of Cattools perform config backups on Cisco Small Business SG300 switches? We are having a hard time getting this working over SSH with TACACS.
Yes, There is a new device type added called 'Cisco.SmallBusiness'. Please have a try on that.
Nanda
this didnt work for me using a cisco small business 300 system
SW version 1.3.7.18 ( date 12-Jan-2014 time 18:02:59 )
Boot version 1.0.0.4 ( date 08-Apr-2010 time 16:37:57 )
HW version V01
System Description: SG300-10MP 10-Port Gigabit PoE Managed Switch
System Up Time (days,hour:min:sec): 05,04:23:34
System Contact:
System Name: MYSYSTEM
System Location:
System MAC Address: 10:8c:cf:cf:2d:dc
System Object ID: 1.3.6.1.4.1.9.6.1.83.10.3
it errors as per:-
it fails ...
it logs on ok and steps thro the config but....eventually
error
"did not receive expected response to command : show running config
tail of debug attached:-
WFMDRetVal=1 Waiting for: "More:"
WFMDRetVal=2 Waiting for: "% Unrecognized command"
WFMDRetVal=3 Waiting for: "% Incomplete command"
WFMDRetVal=4 Waiting for: "Yes/press any key for no"
WFMDRetVal=18 Waiting for: "[27][MYDEVICE>"
WFMDRetVal=19 Waiting for: "[27][MYDEVICE#"
WFMDRetVal=20 Waiting for: "[27][MYDEVICE("
WFMDBuffer="[13] [13]
<W-15:53:57>[13]
<R-15:53:57>[13][10][13][13][27][MYDEVICE#
<W-15:53:57>disable
<R-15:53:57>disab
<R-15:53:57>le
<R-15:53:57>[13][10][13][MYDEVICE>
WFMDRetVal=1 Waiting for: "[27][MYDEVICE>"
WFMDRetVal=2 Waiting for: "[27][MYDEVICE#"
WFMDBuffer="[13][10][13][MYDEVICE>"
<W-15:54:27>[13]
<R-15:54:27>[13][10]
<R-15:54:27>[13]
<R-15:54:27>[27][K
<R-15:54:27>[MYDEVICE>
<W-15:54:28>exit[13]
<D 15:54:28>
<SCRIPT VALUES>
<HOSTNAME=" [MYDEVICE">
<PROMPT VTY=" [MYDEVICE>">
<PROMPT ENABLE=" [MYDEVICE#">
<PROMPT CONFIG=" [MYDEVICE(">
Hello,
Please follow the below steps,
1.Edit the device info.
2.Get in to variations by click the last tab 'Variations' and click on 'Use Variations>>'.
3.Click on 'Full Prompts' and set as I have attached(CSB-Variations.png).
4.Save the details and run the activity. Still have issues post me the debug log.
Thank you Nanda
will try it later today and feedback
Level 8 Solutions - Building Better Networks
www.L8Solutions.co.uk
Sent from my iPhone
How do I do this when the hostname on my device is arbitrary and changes? I do not want to have to enter the hostname on every "Full Prompts" section.
If you have a valid license, please open a support ticket, we will try to avoid the variation input for prompts in the case of arbitrary.
You can mention about this thwack thread in support ticket and ask the support rep to forward the ticket to me.
I don't have the "Variations" tab OR the Cisco.SmallBusiness device. I am running V3.9.1
EDIT: Please disregard. I just noticed that Small Business was added in 3.10. I will update and then check.
