I'm trying to figure out how to get a Top 10 Endpoint graph on the home page for a specific interface.
How is that done? A view? A custom object chart?
Damn Newb....
This might get you close to what you want. So once you have drilled down to the graph you want on the interface you are looking for, click on the Top 10 Endpoints Title so it opens up in a window of its own. This should be showing the Top 10 Endpoints that that interface sees at this point. Copy that URL.
Now add a Custom HTML resource to your homepage or whatever page you want it on. Put it in as an iframe. Use your URL and not mine below as an example. I changed my URL and IP in it for a little privacy . Adjust your height/width to your liking.
<iframe src="http://www.yyy.xxx/Orion/DetachResource.aspx?viewkey=Netflow+EndPoints+Summary&ViewID=65&ResourceID=636&NetObject=NSF%3aT%3aLast+1+Hours%3bFD%3aBoth%3bE%3a10.10.10.10¤tUrl=aHR0cDovL25wbS5tc2xjLmNvbS9Pcmlvbi9UcmFmZmljQW5hbHlzaXMvU3VtbWFyeVZpZXcuYXNweD92aWV3a2V5PU5ldGZsb3cgRW5kUG9pbnRzIFN1bW1hcnkmVmlld0lEPTY1Jm5ldG9iamVjdD1OU0Y6VDpMYXN0IDEgSG91cnM7RkQ6Qm90aDtFOjEwLjIuMS4y" height="700" width="600" frameborder="0"></iframe>
For this test it shows the Top 5 endpoints for my Mail Server.
Whether it is the summary page, Top 10, etc, if the desired Top XX resource is not on the page, you will have to click on the customize page buttom on the top right hand corner and add.
After adding the resource, you will click edit and from there you can apply a filter that will only populate that resource with the desired information. The edit page will contain some examples to get you going:
Show List of Interface Properties Some of the properties that can be used for Filtering Interfaces are :
What type of resource do I select to add?
If you are looking for Top XX Endpoints, then you need to select the Top XX Endpoints.
* Heads up, there are two listed with the same title in the list. If you hover over each one, you will see that one has the classic chart still in its name. Chose the 2nd one as it is a new resource.
How do I get this specific Interface resource on the home page....this is all I need to know how to do .
I'm not seeing this sort of option.
Added resource but I dont see option to change....
I would also like to see this feature.
Please create a feature request. You have my vote for sure.
shawn_b mebway orioncrack, done here: http://thwack.solarwinds.com/ideas/3654
Many Thanks. I have voted
A thing of beauty, thanks for the tip.
Great glad I could help. Do you mind marking my post as helpful or correct answer? I'm closing in on level 10 and need the points .
