I need to create a report that shows all active ports that have nothing connected to them. I am a new-be, any suggestions?
Try this:
SELECT n.Caption, n.IP_Address, i.InterfaceName, i.StatusFROM Nodes nLEFT JOIN Interfaces iON n.nodeID=i.nodeIDWHERE i.AdminStatus = 1ANDi.OperStatus <> 1ORDER BY n.Caption
So (line by line)
1) Device Hostname
2) Device IP Address
3) Interface Description
4) Interface Status (2 = DOWN)
5) Pull data from the Nodes table, variable 'n' on lines 1,2,7
6) Join that data to the Interfaces table, variable 'i' on lines 3,4,6,8,10
7) Match the NodeID from the Nodes table to the NodeID on the Interfaces table
8) Only return results where the Interface is Administratively UP
9/10) AND, Only return results where the Interface does not have an UP state of Operation
11) Sort results alphabetically by n.Caption (hostname)
You can edit as you see fit, but this should give you a pretty good starting point.
also, some people will say that you don't need a variable on columns that are distinct. ie; the Caption column is not on the Interfaces table, so you don't technically need to identify it as 'n.Caption', just putting 'Caption' would work. (Those people would be correct) However, I put a variable on every column I call out of habit. Point is, it works either way.
Message was edited by: Zack Mutchler
I was looking for something I could create with Orion Report Writer if this is
possible. I do not know what to choose as Selected Fields and Filter Results
to get a report that will show all ports that are active but have nothing
connected to them. I have over 6000 ports that are active.
Thanks.
1) Open Orion Report Writer
2) Click on Create New Report
3) Choose Report Type "Advanced SQL"
4) Fill out the General Tab as you wish
5) Click on the SQL tab and copy/paste the script I provided above
6) Field Formatting tab will allow you to edit how the results are output
7) Save the report and then run as needed.
OK, It creates a report with Caption, IP_Address, InterfaceNane and Status Column. However there is no data.
Can you verify a particular node/port combo where you know for sure the interface is "Up/Down"? I know for us, all unused interfaces would be placed in Admin down status. With this query/report, we are only listing devices that are Up/Down. Past that, it would be up to the engineer to identify ports that actually have nothing plugged in versus ports that have actual problems that should be addressed.
Or, it could be that you have 6000+ interfaces and not a single problem
