I need to know if there is a way to collect the Top 25 last 7 day errors and packet loss. If so, how can I do this?
Thnx,
Murph
The following resources are available in the Orion Top XX Lists view. At times, some resources are not present in the default view. You may need to edit the view to see all the possible resources.
I searched in the Current Top 10 Lists>Top 25 Errors and Discards and I cannot find a selection for TOP 25 Errors and Discards for Last 7 days. I cannot find anything when I try to edit the information. Do you have any suggestions for me? These reports are crucial for my current mission.
Thanks in advance,
Are you wishing to create a custom report to send out? or display on the Top 25 on the webpage? I'm not sure what you mean by "collect"
The engineer would like to see the Top 25 Errors and Discards for the last 7 days on the webpage and also collect reports that he can incorporate into a powerpoint slide for a brief.
You can adjust the TOP 10 page to show as many nodes as you want by clicking on the Edit button but this will only reflect your polling settings. As for adjusting the time period, this can only be done when customizing the time-frame from within each chart for that specific node.
You can create a custom SQL report from scratch to combine the data (or modify an existing canned report to your needs) also depending on how versed you are with SQL you might consider using the SQL Reporting Services to create some slick looking reports. Examples of what can be accomplished are listed in the Content Sharing Zone-
