Hi There,
Well I know there are templates to monitor file and folder size on Windows machines. How do I do the same for linux/ redhat machines?
Hello,
You can import the shared templates from thwack. You can find two templates for file and directory size monitoring under "linux" templates:
Kind Regards,
Lukas Belza (SolarWinds development)
Hi Lukas,
Thanks for the reply. Should say I did totally miss that. Can you let me know how to configure the alerts for the same.
Thankd
The scripts return numeric value. You need to set the Warning and Critical Thresholds for the component (on the Edit Application page). By default the alert occurs when component goes to Warning or Critical state.
I hope this helps.
Lukas Belza
Hello, Lukas. Sorry I am new to thwack. Can you please point me to where the shared templates are located ? Our system is not connected to the internet. So, I wonder where I could get the scripts you mentioned above ?
Thanks!
These templates can be found through the in-product Thwack integration under [Settings -> SAM Settings -> Shared thwack Templates]
